It is currently Mon Nov 16, 2026 4:38 am
 Post subject: Dizzy Clamp Bolt Size
PostPosted: Sat Jan 23, 2016 9:55 am
What is the thread size of the dizzy clamp down bolt. I know it has a head that is 7/16", but I can't figure out what thread it has. Thanks.
PostPosted: Sat Jan 23, 2016 10:33 am
Never mind. I got it.
 Post subject: So What Size Is It ????
PostPosted: Sat Jan 23, 2016 10:59 am
Car Model: '64 Valiant Convertible
1/4-20 ??? 1/4-28 ??? Do tell... :shock:
PostPosted: Sat Jan 23, 2016 12:04 pm
I used a valve cover bolt. My problem was the bolt wasn't going in right. I pulled down the brace that has the hole in it for the bolt, to get it below it. I screwed in that bolt, and could see it fit. After moving it back up, I had to turn that brace a few times, so I could line up the bolt straight. I finally got it that way. So it is the same size as the valve cover bolts, whatever they are.
PostPosted: Sat Jan 23, 2016 1:21 pm
Car Model: Toad Wagon
Yup, 1/4-20.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Sun Jan 24, 2016 4:36 am
1/4-20 for earlier engines (pre 80s?) and 5/16-18 for later engines.
I don't know the cutoff year, but somewhere in the late 70s, I believe. I have a couple of cast crank blocks and they are 5/16-18.
Users browsing this forum: Ahrefs [Bot], DuckDuckGo [Bot] and 4 guests
