| Dizzy Clamp Bolt Size https://slantsix.org/forum/viewtopic.php?t=59013 |
| Author: | 63dartdude [ Sat Jan 23, 2016 9:55 am ] |
| Post subject: | Dizzy Clamp Bolt Size |
What is the thread size of the dizzy clamp down bolt. I know it has a head that is 7/16", but I can't figure out what thread it has. Thanks. |
| Author: | 63dartdude [ Sat Jan 23, 2016 10:33 am ] |
Never mind. I got it. |
| Author: | neilskiw [ Sat Jan 23, 2016 10:59 am ] |
| Post subject: | So What Size Is It ???? |
1/4-20 ??? 1/4-28 ??? Do tell... |
| Author: | 63dartdude [ Sat Jan 23, 2016 12:04 pm ] |
I used a valve cover bolt. My problem was the bolt wasn't going in right. I pulled down the brace that has the hole in it for the bolt, to get it below it. I screwed in that bolt, and could see it fit. After moving it back up, I had to turn that brace a few times, so I could line up the bolt straight. I finally got it that way. So it is the same size as the valve cover bolts, whatever they are. |
| Author: | Old6rodder [ Sat Jan 23, 2016 1:21 pm ] |
Yup, 1/4-20. |
| Author: | Dart270 [ Sun Jan 24, 2016 4:36 am ] |
1/4-20 for earlier engines (pre 80s?) and 5/16-18 for later engines. I don't know the cutoff year, but somewhere in the late 70s, I believe. I have a couple of cast crank blocks and they are 5/16-18. Lou |
