It is currently Fri Nov 27, 2026 12:37 pm
 Post subject: Comp. Ratio Calculator
PostPosted: Wed Jan 27, 2016 4:11 pm
Anyone ever use the "United Engine & Machine", comp. calculator, that is on their website? I used it along side my Mopar engines performance book and
the numbers are almost identical. Calculator gives both static and dynamic ratios.
Ski boot laces can get your slant six home.
PostPosted: Wed Jan 27, 2016 4:29 pm
Yes I use it.
Rick
PostPosted: Thu Jan 28, 2016 2:56 pm
I'm working up a build on a 198 and having actual numbers to go by should prevent, "work done in vain". I also found useful info on "classic inlines".
