It is currently Mon Nov 16, 2026 12:44 am
 Post subject: Easy Hard Question!
PostPosted: Tue Feb 09, 2016 3:06 pm
Just took ownership of a 66 valiant with a single barrel, the linkage to the carb seem off. can't find any images or documents for how the pedal attaches the correct way to the linkage and via the accelerator pump linkage as well. They way it rest right now, will not work. the accelerator pump is not getting the correct travel and the opposite way of moment. (via. it drops the plunger instead of pulling it up for the gain in full on the throttle command)
Great to find a place for this awesome motors
PostPosted: Tue Feb 09, 2016 3:15 pm
The factory service manual shows the throttle linkage in detail. The accelerator pump being moved down by spring pressure is what squirts the fuel.
PostPosted: Tue Feb 09, 2016 3:25 pm
ahhh! i've been looking for the problem in the wrong area, it's on the wrong side at the pedal to linkage, gonna try to swap it , but that's where it needs to rotated.
PostPosted: Wed Feb 10, 2016 7:53 am
Go to the articles section of this site and review the choke adjustment article for some nice detail.
http://www.slantsix.org/articles/choke- ... o/bbs1.jpg
