It is currently Wed Sep 30, 2026 1:37 am
PostPosted: Mon Mar 14, 2016 3:05 pm
Car Model: 1963 Plymouth Valiant
Will this work on a 170 exhaust ?
Look at this on eBay:
https://www.ebay.com/ulk/itm/121354580422
BUICK 1940 - 1956 MANIFOLD DAMPER THERMOSTAT COIL
Douglas Hawkins
PostPosted: Mon Mar 14, 2016 3:37 pm
Here is what you are looking for: CLICK ME
You might try calling NOS parts dealers such as old car parts northwest or Arizona parts and asking for the following part numbers:
3004664
2084797
PostPosted: Mon Mar 14, 2016 5:09 pm
Kool! I will check that out. I might have to buy that whole unit.
How much of a difference does it make if that unit isn't working? Cause it's hard to tell on mine.
Douglas Hawkins
PostPosted: Mon Mar 14, 2016 5:38 pm
It can make quite a big difference. The intake manifold must reach and maintain a high operating temperature to assist with eliminating fuel puddling in the intake manifold, especially in colder climate. At the same time, if the flapper gets stuck open it can overheat the intake and cause other problems.
PostPosted: Tue Mar 15, 2016 7:44 am
Di you know at what temperature it goes from normal operating to over heating?
1982 dodge w150 4 speed
PostPosted: Tue Mar 15, 2016 7:53 am
Nope. Not off the top of my head.
PostPosted: Tue Mar 15, 2016 10:11 am
When is the flapper closed? Turned all the way clockwise or counter clockwise?
 Post subject: open vs closed
PostPosted: Tue Mar 15, 2016 11:02 am
As I recall, the flapper is positioned to let about equal amounts of exhaust gas out and also hitting the underside of the intake manifold, as it heats up it turns clockwise to direct the flow almost entirely to the exhaust pipe, but the downstream end of the flapper still leaves some gap for gas to get to the intake. I measured my intake after warming up one time, I believe it was about 250 F at the runners.
brian
https://tinyurl.com/yynpj4v2
 Post subject: AZ parts
PostPosted: Tue Mar 15, 2016 11:27 am
Last I looked (a few months or so ago) Arizona parts had the complete kit for around $90.
brian
PostPosted: Wed Mar 16, 2016 4:37 pm
Ok I think I have officially found the hardest part to locate. Only found one so far for $135.
Douglas Hawkins
PostPosted: Thu Mar 17, 2016 4:42 pm
Ok folks found a complete set with both springs. For less than $100.
Thanks for the help everyone.
Douglas Hawkins
PostPosted: Thu Mar 17, 2016 5:45 pm
Douglas Hawkins
PostPosted: Thu Mar 17, 2016 10:54 pm
Where , any more to be had ?
Business , or Private Party ?
Thanks!
Users browsing this forum: Google [Bot] and 24 guests
