It is currently Thu Nov 26, 2026 6:31 pm
PostPosted: Thu Mar 24, 2016 1:27 pm
Anyone out there know what each of the wires do that go from the wiper switch to the wiper motor on a 1970 D100 Truck? My switch is pretty messed up and the aftermarket ones are pretty reasonable. But you have to know what each of the wires do. I have the wiring diagram, but that doesn't tell you what the wires do.
The wire colors are:
Large Light Blue from harness = presumed to be the main power.
Red = ?
Dark Blue = ?
Green = ?
Brown = ?
Thanks, Craig
 Post subject: Wich Model Motor?
PostPosted: Thu Mar 24, 2016 3:57 pm
Car Model: '64 Valiant Convertible
http://www.mymopar.com/index.php?pid=77
Above is a link to a page with part numbers of the various wiper motors.
2 speed, 3 speed, and variable. The wiring of the switch will likely be dependent upon the particular motor in your vehicle.
Also, if your wiper switch is out, look for a part number on it. That number may cross to a newer switch for the motor you have.
Users browsing this forum: DuckDuckGo [Bot] and 3 guests
