It is currently Thu Jan 01, 2026 8:58 pm
 Post subject: Carb choice
PostPosted: Thu Apr 21, 2016 5:26 pm
My 67 has a 2bbl and I found a couple carbs to use. Any advice on which is better for performance or reliability is greatly appreciated. The motor is open .040, had .100 shaved off the head and has the big valves. Not sure of cam or any other block work as it was already together when I bought it. Carbs are: Carter BBD, a Model# 2258 Carter, and a Stromberg WW. Thanks for any help/advice.
PostPosted: Fri Apr 22, 2016 8:10 am
Which one is in the best condition? The only feedback I've seen on the Stromberg is good power, but poor economy. I expect one could change that if smaller jets could be found.
