It is currently Thu Nov 26, 2026 10:11 am
 Post subject: 66 Barracuda brake size
PostPosted: Tue May 17, 2016 10:00 am
What size rear brakes were on a 66 Barracuda with a 273 V-8? Car has 10 fronts did the 7 1/4 rear have 9's or 10's? Thanks
PostPosted: Tue May 17, 2016 10:48 am
Cars with 7-1/4" rear axles came with 9" or 10" brakes, front and rear, depending on the whole-vehicle specifications and/or what was ordered at new-car purchase time. Always the same diameter front and rear, never 10" fronts with 9" rears or vice versa. The V8 cars came with 10" brakes as standard equipment.
PostPosted: Tue May 17, 2016 6:06 pm
OK, Thanks. Putting my 66 Cuda back to stock, and wasn't sure which was the correct 7 1/4 rear.
PostPosted: Tue May 17, 2016 9:01 pm
The rear axle assembly isn't different for 9" vs. 10" brakes; it's just a matter of what parts are bolted onto the ends of the axle tubes.
PostPosted: Wed May 18, 2016 4:06 am
I was/am aware of that. I Have a couple of different rears, of unknown years
both 9 and 10 inch brakes, plus later LBP 10 brake pieces. just wanted to put in a rear with the correct configuration. Thanks
Users browsing this forum: No registered users and 17 guests
