| Ram "Mini" Starter Installed https://slantsix.org/forum/viewtopic.php?t=59621 |
| Author: | Dart270 [ Tue May 10, 2016 7:57 am ] |
Yep, have one on my 68 Dart with 200-4R swap. Sounds a bit too GM for me, but works great and only 7 lbs. Lou |
| Author: | Old6rodder [ Tue May 10, 2016 10:00 am ] |
Ditto. Wound up with one on my HAMBster, and love it. Will be putting one on the animation slant in our float next, then another one'll go on the shelf to wait its turn into El Toad. Now if the contact discs in the solenoids'll just last ...... |
| Author: | Augie Dog [ Sat Jun 04, 2016 8:53 am ] |
| Post subject: | Mini Ram Starter |
So this is an upgrade I am interested in doing. The /6 starters have always been junk in my opinion. Can you tell me more about this starter? What did it come off of and is this something that can be found at a salvage yard? I was under the impression a starter from the Dodge Caravan 3.0 would also work on our slants. I have an 87 D150 Thanks |
| Author: | coconuteater64 [ Sat Jun 04, 2016 9:32 am ] |
| Post subject: | Re: Mini Ram Starter |
Quote: So this is an upgrade I am interested in doing. The /6 starters have always been junk in my opinion. Can you tell me more about this starter? What did it come off of and is this something that can be found at a salvage yard? I was under the impression a starter from the Dodge Caravan 3.0 would also work on our slants. I have an 87 D150
I don't know about the Caravan starter, but the 3.9 Dakota starter cranks my truck with barely a flick of the key.
Thanks |
| Author: | SlantSixDan [ Sat Jun 04, 2016 11:09 am ] |
Nope, they're not junk. They work fine for years and decades -- until they're "remanufactured". See this thread.Quote: Can you tell me more about this starter? What did it come off of and is this something that can be found at a salvage yard?
See this thread and this one and this one. This is the newest-design starter that will fit; for another readily-available choice see here.Quote: I was under the impression a starter from the Dodge Caravan 3.0 would also work on our slants.
No, it will not fit -- not even a little bit.
