It is currently Thu Jun 18, 2026 5:58 pm
 Post subject: bent pushrod repair?
PostPosted: Tue May 10, 2016 6:50 pm
I blew it and torqued down my valvetrain with 1 pushrod not seated in the lifter, bent it pretty good. I was able to pound it straight with just a ripple of a tweak. Can I run it or is that an absolute no-no? Does anyone got a spare mechanical pushrod they want to donate?
I didn' t buy it, I built it.....
PostPosted: Tue May 10, 2016 6:55 pm
Roll it across a piece of glass to see how straight it is. If you have a stock cam and springs you can probably run it for quite awhile.
If you have heavier springs, it's probably going to bend again shortly. :D
PostPosted: Wed May 11, 2016 7:01 am
I straightened it, rolled it and it just has a little wave in it. I bought a new one from Rockauto, 4 bucks. Needed a rubber valve cover gasket anyway.
 Post subject: bent push rod
PostPosted: Thu May 12, 2016 4:39 pm
Late the conversation, but I have two comments:
1. When I was a kid, my Dad straightened out a push rod and reused it with no issues in his Ford 300 cu. in. I6.
2. I would never straighten out a push rod and reuse it.
Glad to hear you succumbed to logic, unlike my Dad.
brian
https://tinyurl.com/yynpj4v2
PostPosted: Thu May 12, 2016 5:59 pm
...expediency is not hindered by logic.....
My dad would never straighten a pushrod....Id do one fer fun.
PostPosted: Thu May 12, 2016 11:58 pm
In a motor that turns rpm or has a lot of valve spring I wouldn't either. But on a stock Slant or a tractor motor I've done it many times.
I saw Floater Wasson pound 15 of his straight on a 9 second Super Gas BBC Nova and run it the rest of the weekend.😃
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
