It is currently Wed Nov 25, 2026 11:47 pm
 Post subject: Something seems wrong...
PostPosted: Sun Jun 19, 2016 3:19 pm
Okay...I'm attempting to redo the whole front end on my 72 Valiant. Just eyeballing everything, but to make things look relatively straight, one tie rod is adjusted way in and the other way out. Also, if I turn the wheel lock to lock and divide by 2, the wheel is about 90 degrees from straight. Any ideas on where I'm messing up?
If I was half as smart as I thought I was 30 years ago, I'd be twice as smart as I am now
PostPosted: Sun Jun 19, 2016 4:38 pm
does a 72 Valient have a 'rag joint' ,,, a fiber disk that resides between the steering column shaft and the steering box shaft, if so sounds like it is 180 out. Uncouple the joint, rotate the steering wheel 180 and put it back together...I had the same issue on the 83 D150 and that is what I did to fix it.
PostPosted: Sun Jun 19, 2016 4:39 pm
Make the tie rods equal and see if you're closer.
PostPosted: Sun Jun 19, 2016 6:00 pm
Thanks, I will check both of these
PostPosted: Sun Jun 19, 2016 8:03 pm
No, there is no rag joint in the steering system of a Valiant.
