It is currently Wed Dec 31, 2025 9:50 pm
 Post subject: HEI Model without Relay
PostPosted: Mon Jun 20, 2016 5:44 pm
I did the HEI Model without the relay because I did all new wiring. The Ron Francis tech said that their wiring was set up for HEI and no relay was necessary. So far it is running good. But the random stall makes me wonder if I should have used the relay.
So, do you need the relay with all new wiring and HEI?
Thanks, Craig
PostPosted: Mon Jun 20, 2016 5:45 pm
I meant HEI "Mod". Dang autocorrect
PostPosted: Mon Jun 20, 2016 5:53 pm
If you're smart, yes, you use a relay.
Users browsing this forum: Google [Bot] and 20 guests
