It is currently Fri Oct 09, 2026 4:48 pm
 Post subject: fuel pump clearence
PostPosted: Mon Apr 30, 2018 11:41 am
Just pulled old 1964 /6 with cracked block and was surprised to see bottom of fuel pump in contact with corner of motor mount & bracket. Mounts were new last summer. I ground a little clearance in mount and bolted it on the newer 73 /. Pumps appear to be identical replacement units. Any ideas on what gives with the zero clearance on the pump?
Steve
 Post subject: Re: fuel pump clearence
PostPosted: Tue May 01, 2018 5:50 am
Do you have a picture, so we can see what's going on?
Users browsing this forum: Amazon [Bot], Google [Bot] and 25 guests
