It is currently Tue Oct 13, 2026 11:32 pm
PostPosted: Fri Sep 02, 2016 4:28 am
Car Model: 1968 Barracuda - Fastback
Can someone identify my engine casting #? I can't seem to find any reference to my sequence and want to know if it's at least date-matched. Here it is: PT225R22430823 I have triple checked the numbers but can't seem to identify this particular casting. Any help is appreciated. The engine is in a 68 Barracuda.
'68 Barracuda - taking advice on increasing street torque, power, & road handling. Click To See It
PostPosted: Fri Sep 02, 2016 8:57 am
Well, other than it being a 225 I got nothing. :shrug:
 Post subject: RE: "I got nothing"
PostPosted: Fri Sep 02, 2016 10:42 am
Thanks @coconuteater64, I appreciate you poking around.
PostPosted: Fri Sep 02, 2016 1:21 pm
Poser
Slant Six Dan is the guru on this stuff - hopefully he will help ya out. If I remember correctly 225R is a passenger car engine. The month and day of casting should follow. I have numbers on heads - but those can be interchanged. So looks like ya have a car engine in a car. What big help I am! PM Dan. :lol:
 Post subject: Yep...
PostPosted: Fri Sep 02, 2016 3:10 pm
Dan could get this dialed in better, here is what I know:
PT= Trenton Engine Plant
225= 225 slant six
R=Regular Fuel
2243= Date Code (I think using the 10,000 day Chrysler Calender this is September 18, 1967)...
0283=Sequence Number
 Post subject: engine codes
PostPosted: Fri Sep 02, 2016 5:36 pm
I like how "R" means regular fuel, but after about 50 years, that doesn't really mean the same thing any more....b
https://tinyurl.com/yynpj4v2
 Post subject: Lol...
PostPosted: Fri Sep 02, 2016 11:34 pm
Some of the other codes that are strictly very late 60's can be:
L or LC for low compression
P for Premium fuel (that would usually be "Ethyl" in those days)
S for Special Engine
HP for High Performance
HC for High Compression
(Note most of these don't apply to the slant six...)
Depending on placement in the sequence R,X,S a maltese cross, etc.. can mean overbores, bearing size changes, etc....
PostPosted: Sat Sep 03, 2016 10:41 am
What's the block casting number (on the manifold side of the block)?
PostPosted: Tue Sep 06, 2016 9:35 am
Dan, the numbers on the manifold side of the block are below.
Uppermost > 08305:
Main numbers? > 2483430-12
Upside down near the starter > 2140
The paint on the main numbers is a bit heavy, the third-digit could be a 6, which would make this a '66 block (I think). I'll give it a better look and get back to you all.
Thanks to all who have responded!
PostPosted: Tue Sep 06, 2016 11:19 am
Yup, 2463430 is a '63-'67 RG block with three freeze plugs. That's a little interesting: given the engine build date code DusterIdiot correctly decoded (2243 = 18 September 1967), and the engine's presence (originally?) in a '68 model, it theoretically should've had the '68-'76 2806830 RG block with five freeze plugs. Nevertheless, there's no reason why the earlier block would be incompatible with any aspect of a '68 engine or vehicle. The '68-up large-counterbore crankshaft is fully compatible with the '67-down block and vice versa. The "2140" cast number you found (7 June 1967) makes me think what we're seeing here is a '68-model engine build up with a '67 block. Block cast in June, engine assembled in September to go into a '68 car, that adds up.
 Post subject: Dan + all who replied
PostPosted: Tue Sep 06, 2016 1:14 pm
Thanks to all - this is an invaluable resource as a slant-6 owner. The collective knowledge and willingness to share your information is incredible. Best, -Chris
PostPosted: Tue Sep 06, 2016 1:17 pm
For what it is worth, I once bought a 225 that had been removed from a 68 Dart (original motor to car). It was a three freeze plug block but the engi e ID number on the pad had been stamped over and a maltese cross added to the end (I believe that means .010 undersize bearing from the factory). I think it was a 67 engine that was remachined by the factory and installed in a 68 Dart. I used several post-68 904 transmissions with that engine and had no problems.
Users browsing this forum: Bing [Bot] and 19 guests
