It is currently Sun Nov 15, 2026 12:19 pm
 Post subject: choke gasket
PostPosted: Fri Sep 16, 2016 2:04 pm
Car Model: 1938 Plymouth 4 dr. sedan
Am using a different carb on my /6 that has an electric choke, so don't need the remote choke anymore. Would like to use a block off plate where choke went and am looking for the high temp gasket that went under the choke against the exhaust manifold or any other ideas that would work. More later on the different carb. Is 90* to original for linkage, needed an adapter to turn and custom throttle and kick down arm for linkage hook up. Thanks for your help.
Street rod an old car and then drive/use it. I'm a NSRA safety inspector if anyone ever wants that done to their car.
PostPosted: Sat Sep 17, 2016 11:57 am
That open-hole choke stove with the gasket and cup are on '70-'72 exhaust manifolds only. Real pain in the nuts -- leak point, and the gasket is no longer available. I have _one_ new gasket for that application; send me a PM if you'd like to buy it.
