| choke gasket https://slantsix.org/forum/viewtopic.php?t=60180 |
| Author: | Mongrel147 [ Fri Sep 16, 2016 2:04 pm ] |
| Post subject: | choke gasket |
Am using a different carb on my /6 that has an electric choke, so don't need the remote choke anymore. Would like to use a block off plate where choke went and am looking for the high temp gasket that went under the choke against the exhaust manifold or any other ideas that would work. More later on the different carb. Is 90* to original for linkage, needed an adapter to turn and custom throttle and kick down arm for linkage hook up. Thanks for your help. |
| Author: | SlantSixDan [ Sat Sep 17, 2016 11:57 am ] |
That open-hole choke stove with the gasket and cup are on '70-'72 exhaust manifolds only. Real pain in the nuts -- leak point, and the gasket is no longer available. I have _one_ new gasket for that application; send me a PM if you'd like to buy it. |
