| is there a simple diagram https://slantsix.org/forum/viewtopic.php?t=60198 |
| Author: | USAJon [ Tue Sep 20, 2016 1:43 pm ] |
| Post subject: | is there a simple diagram |
looking for simple diagram for heil conversion our 1982 needs that upgrade. thanks.. |
| Author: | Rick Covalt [ Tue Sep 20, 2016 1:57 pm ] |
| Post subject: | link |
some in the link http://www.slantsix.org/forum/viewtopic ... ei+drawing |
| Author: | USAJon [ Tue Sep 20, 2016 3:01 pm ] |
| Post subject: | thanks bro |
just purchased this http://www.ebay.com/itm/252345303319 |
| Author: | USAJon [ Mon Sep 26, 2016 9:20 am ] |
| Post subject: | my dist has multi wires ? |
http://i328.photobucket.com/albums/l341 ... grpmkz.jpg |
| Author: | Reed [ Mon Sep 26, 2016 10:02 am ] |
| Post subject: | Re: my dist has multi wires ? |
Quote: http://i328.photobucket.com/albums/l341/joe_smith35/dist%20001_zpsyygrpmkz.jpg
That is a lean burn distributor with dual pickups and no vacuum or mechanical advance. You do have the desireable late model distirbutor hold down system, though.If you want an ignition system that has any kind of timing advance (mechanical and/or vacuum) you will need to get a non-lean burn electronic ignition distributor. |
