It is currently Fri Nov 13, 2026 5:06 pm
PostPosted: Wed Sep 21, 2016 3:37 pm
I'm thinking about sticking a slant six into a 71 B-body. The motor (and trans) will be coming from an 82 D150. I am unsure about some parts fitting the b body, Like oil pan, exhaust manifold, water pump outlets, are they going to be on the right side for the radiator?
PostPosted: Wed Sep 21, 2016 3:51 pm
Put the oil pan, oil pickup tube, and motor mounts from the 71 onto the engine and it will slide right in.
PostPosted: Wed Sep 21, 2016 6:04 pm
Dont have the original motor in the 71
PostPosted: Wed Sep 21, 2016 6:24 pm
Do you have a slant in the 71 now? If so, use the bits from it.
If you have NO motor at all in the 71, you will be hunting for the pieces I mentioned.
Users browsing this forum: DuckDuckGo [Bot] and 6 guests
