It is currently Mon Nov 16, 2026 2:07 pm
 Post subject: Carb mixture and vacuum
PostPosted: Fri Sep 23, 2016 3:56 pm
Well on my carter bbd, 225ci, I hooked up a vacuum gauge directly to a port that sticks up off the intake manifold. It is giving me a solid 23 in. I am trying to set idle mixture, watching gauge but the only time I see and hear something happen is if I turn the screws bascially all the way in, if I start backing them off I never see or hear a change, so much so that the screws are about to fall out. All the info I read says that when you back them out , at some point the engine starts to bog down again.???
Maybe I have too much vacuum??
66 dodge dart 270, 225ci, 3.7l, L6
PostPosted: Fri Sep 23, 2016 3:59 pm
Many emissions carburetors have a very small idle mixture change with the adjustment needles. If you tried what you have with an aftermarket Holley non-emission carb you could easily flow enough fuel to bog the engine as the needle adjustment makes a large difference and the idle circuit will flow plenty of fuel.
