It is currently Wed Nov 11, 2026 11:35 am
PostPosted: Tue Sep 20, 2016 1:43 pm
looking for simple diagram for heil conversion our 1982 needs that upgrade.
thanks..
slant six's RULE!
http://www.usajon.com
 Post subject: link
PostPosted: Tue Sep 20, 2016 1:57 pm
some in the link
http://www.slantsix.org/forum/viewtopic ... ei+drawing
 Post subject: thanks bro
PostPosted: Tue Sep 20, 2016 3:01 pm
just purchased this
http://www.ebay.com/itm/252345303319
slant six's RULE!
PostPosted: Mon Sep 26, 2016 9:20 am
http://i328.photobucket.com/albums/l341 ... grpmkz.jpg
slant six's RULE!
PostPosted: Mon Sep 26, 2016 10:02 am
http://i328.photobucket.com/albums/l341/joe_smith35/dist%20001_zpsyygrpmkz.jpg
That is a lean burn distributor with dual pickups and no vacuum or mechanical advance. You do have the desireable late model distirbutor hold down system, though.
If you want an ignition system that has any kind of timing advance (mechanical and/or vacuum) you will need to get a non-lean burn electronic ignition distributor.
