It is currently Thu Nov 19, 2026 7:25 pm
PostPosted: Mon Nov 28, 2016 9:23 am
Hi all, I'm considering buying a rebuilt long block from Craigslist. The guy bought it in a lot of 7 engines and has no use for it. It was wrapped and palleted and obviously never used. Since I can't run it, what should I be looking for as indicatiors of build integrity? Thanks.
PostPosted: Tue Nov 29, 2016 8:49 am
Look for a rebuilder's tag on it... those tags will often give over-bore and crank size info.
Do a general inspection... is it nice & clean? New freeze plugs? Well painted with no "paint over grease" sort of stuff.
Spray a little oil thru the spark plug holes and then rotate the engine with a wrench, to see if it spins freely.
PostPosted: Wed Nov 30, 2016 11:42 am
Thanks Doc - appreciate the input. I'm going to check it out this week. I know it's generally frowned upon to pick up a rebuild vs. building one from the ground up, but I've had my engine on a stand for over a year and just have had no time to get to it. Maybe someday. And I think I can get this long block for a good enough price to offset the risk.
PostPosted: Fri Dec 02, 2016 8:05 am
So I picked it up yesterday - well, actually the guy delivered it :D . It is clean, looks fresh and it cranked over nice and smooth by hand. Couldn't locate any markings indicating overbore or crank size, but I plan on doing further inspection this weekend. I'm also going to pull the head off and see what's doing inside. He threw in another used /6 head he had laying around and with delivery, I paid $450. We'll see what's in store and I'm tempering my own expectations, but I think it was worth a shot. Thanks!
Users browsing this forum: Bing [Bot] and 5 guests
