| What to look for in a 2nd hand rebuilt long block https://slantsix.org/forum/viewtopic.php?t=60503 |
| Author: | retrorobot [ Mon Nov 28, 2016 9:23 am ] |
| Post subject: | What to look for in a 2nd hand rebuilt long block |
Hi all, I'm considering buying a rebuilt long block from Craigslist. The guy bought it in a lot of 7 engines and has no use for it. It was wrapped and palleted and obviously never used. Since I can't run it, what should I be looking for as indicatiors of build integrity? Thanks. |
| Author: | Doctor Dodge [ Tue Nov 29, 2016 8:49 am ] |
Look for a rebuilder's tag on it... those tags will often give over-bore and crank size info. Do a general inspection... is it nice & clean? New freeze plugs? Well painted with no "paint over grease" sort of stuff. Spray a little oil thru the spark plug holes and then rotate the engine with a wrench, to see if it spins freely. DD |
| Author: | retrorobot [ Wed Nov 30, 2016 11:42 am ] |
Thanks Doc - appreciate the input. I'm going to check it out this week. I know it's generally frowned upon to pick up a rebuild vs. building one from the ground up, but I've had my engine on a stand for over a year and just have had no time to get to it. Maybe someday. And I think I can get this long block for a good enough price to offset the risk. |
