It is currently Fri Nov 06, 2026 9:20 am
PostPosted: Thu Apr 25, 2019 9:01 am
Supposed to have been pulled from an '81 pick up. Does it being a truck transmission make it a difficult swap into an A body? Do I need to keep looking for an A body 904?
PostPosted: Thu Apr 25, 2019 10:50 am
Yes, looks like a Slant 6 904. Should be a direct swap to any A-body. Assume you know about large/small crank hub/pilot hole and converter match up...
PostPosted: Thu Apr 25, 2019 10:53 am
Yes I am aware of the input shaft sizes and such. That is one reason for the swap. So does it matter that it came from a truck? Still a direct swap?
I have a '63 Dart with push button 904. I am not using a 63 crank.
PostPosted: Thu Apr 25, 2019 1:06 pm
The 81 904 will likely have more clutches than a car slant, a wide-ratio gearset, and it will be lockup. None of these are really a bad thing unless you are racing and don't like the larger RPM drop between 1st and second gears.
PostPosted: Thu Apr 25, 2019 1:14 pm
The numbers are:
4058383
http://mymopar.com/downloads/transguide.pdf
PostPosted: Thu Apr 25, 2019 1:38 pm
Is the rpm drop that significant? I am trying to build a relatively fast car so maybe I need to keep looking.
PostPosted: Thu Apr 25, 2019 1:55 pm
According to Tom Hand's Torqueflite book, 4058383 is 1981 Dodge truck, 225, 904, wide ratio gear set, lock up converter.
PostPosted: Thu Apr 25, 2019 2:16 pm
Third gear is 1:1 in both the older narrow gear ratio and the later wide ratio gearset.
Wide ratio- 2.74, 1.54, 1
Close ratio- 2.45, 1.45, 1
Your can figure out what that means for your gearing and acceleration and what it means in relation to your power band.
PostPosted: Thu Apr 25, 2019 3:23 pm
I'm going to keep looking.
