It is currently Fri Nov 20, 2026 11:39 pm
 Post subject: 727 transmission
PostPosted: Sat Jan 07, 2017 8:43 pm
Car Model: 1968 Plymouth Barracuda slant 6 super six 4 speed.
Hey gang, I got a 65-68 truck/van small block 727 short tail shaft transmission, I want to swap the guts and tail shaft into the slant 6 727 case. Is this do able and what torque converter will be needed? This will be going into my power wagon turbo slant 6 project. Thank you!
I'm human and I do things for the universe.
PostPosted: Sat Jan 07, 2017 9:20 pm
Yes! Use the kickdown band to match the case and use the front pump to match the input shaft. Use the output shaft to match the tailshaft.
PostPosted: Sat Jan 07, 2017 9:26 pm
So being that the slant 6 727 I have is ONLY the case. My small block 727 guts will interchange?
PostPosted: Sat Jan 07, 2017 9:51 pm
Yes! Put all the 727 stuf into the slant six case. Just make sure you use the output shaft to match the tailshaft housing.
