| 727 transmission https://slantsix.org/forum/viewtopic.php?t=60638 |
| Author: | Magnumforce1987 [ Sat Jan 07, 2017 8:43 pm ] |
| Post subject: | 727 transmission |
Hey gang, I got a 65-68 truck/van small block 727 short tail shaft transmission, I want to swap the guts and tail shaft into the slant 6 727 case. Is this do able and what torque converter will be needed? This will be going into my power wagon turbo slant 6 project. Thank you! |
| Author: | Reed [ Sat Jan 07, 2017 9:20 pm ] |
Yes! Use the kickdown band to match the case and use the front pump to match the input shaft. Use the output shaft to match the tailshaft. |
| Author: | Magnumforce1987 [ Sat Jan 07, 2017 9:26 pm ] |
So being that the slant 6 727 I have is ONLY the case. My small block 727 guts will interchange? |
| Author: | Reed [ Sat Jan 07, 2017 9:51 pm ] |
Yes! Put all the 727 stuf into the slant six case. Just make sure you use the output shaft to match the tailshaft housing. |
