It is currently Sun Nov 22, 2026 7:59 pm
PostPosted: Fri Apr 21, 2017 9:23 am
Have read that it is possible to soften old hard rubber gaskets by soaking them in a mixture of Oil of Wintergreen and rubbing alcohol and was unable to find any answers using the Search option. Has anyone tried this method?
I am trying to resurrect a 1972 Power Wagon - sorry but not a slant. The gas tank is in the cab and I have been unable to locate NOS/useable gaskets for where the gas filler neck exits the cab or where the gas filler tube enters the gas tank. The ones I have are hard as a rock but would be reusable if I could soften them.
Thanks in advance for help.
Fred
PostPosted: Fri Apr 21, 2017 2:13 pm
I don't know if this helps...
I've put old rubber gaskets in paint thinner.
They get soft and really really big.
Then slowly shrink back to size.
PostPosted: Fri Apr 21, 2017 2:19 pm
Lacquer thinner will do the same thing. They will swell about 3 times their normal size and be back to normal after they dry.
Van's Auto may have new gaskets.
PostPosted: Fri Apr 21, 2017 2:37 pm
Poser
WOW!! I may have a new use for thinner!!!! :shock:
PostPosted: Fri Apr 21, 2017 5:33 pm
Besides huffing it? :lol:
PostPosted: Fri Apr 21, 2017 8:10 pm
Van's has a new neck to cab grommet and a new tank sending unit, thanks.
I will use the paint thinner on the grommets to see how that works.
Thanks for the help & Information.
Fred
Users browsing this forum: Amazon [Bot] and 4 guests
