It is currently Mon Jun 01, 2026 9:24 pm
 Post subject: HeI coil wire
PostPosted: Wed Mar 22, 2017 11:20 pm
Just picked up a coil and heat sink bracket from the yard. Was wondering what's are my options for getting a coil wire to work with the stock coil and the mopar dist cap.
It's the kind with a skinny prong down in the hole.
PostPosted: Fri Mar 24, 2017 8:23 am
I used the same coil wire that I was using with the points set up. Not ideal but my car runs good.
PostPosted: Fri Mar 24, 2017 9:19 am
I removed the "skinny" GM terminal and then recrimped it onto my coil wire. It is working just fine.
1976 Feather Duster /6 4sp
1984 W100 318 727 np241
1972 'Cuda 340 4sp
1985 D250 360 46RH
PostPosted: Sat Mar 25, 2017 2:33 pm
+1 I just took the coil wire and cut as much wire as I could get to for both plugs from the donor vehicle.
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Sat Mar 25, 2017 7:14 pm
One of my HEI, setups, I ordered wires from Magnecore, and told them the length and ends I wanted on the coil wire.
The other, got the ends and length of wire from NAPA, and crimped, myself.
PostPosted: Mon Mar 27, 2017 1:03 am
I ended up using a piece of I believe solid core scat plug wire. Used used ends from the gm wire and mopar wire. Works fine. My buddy has enough spare pieces to do a full set of plug wires.
Hei is on and works.
