| HeI coil wire https://slantsix.org/forum/viewtopic.php?t=60921 |
| Author: | drgonzo [ Fri Mar 24, 2017 8:23 am ] |
I used the same coil wire that I was using with the points set up. Not ideal but my car runs good. |
| Author: | afastcuda1970 [ Fri Mar 24, 2017 9:19 am ] |
I removed the "skinny" GM terminal and then recrimped it onto my coil wire. It is working just fine. |
| Author: | carlherrnstein [ Sat Mar 25, 2017 2:33 pm ] |
Quote: I removed the "skinny" GM terminal and then recrimped it onto my coil wire. It is working just fine.
+1 I just took the coil wire and cut as much wire as I could get to for both plugs from the donor vehicle.
| Author: | Charrlie_S [ Sat Mar 25, 2017 7:14 pm ] |
One of my HEI, setups, I ordered wires from Magnecore, and told them the length and ends I wanted on the coil wire. The other, got the ends and length of wire from NAPA, and crimped, myself. |
| Author: | kielbasa [ Mon Mar 27, 2017 1:03 am ] |
I ended up using a piece of I believe solid core scat plug wire. Used used ends from the gm wire and mopar wire. Works fine. My buddy has enough spare pieces to do a full set of plug wires. Hei is on and works. |
