It is currently Fri May 15, 2026 12:39 pm
PostPosted: Sun Mar 26, 2017 7:30 am
My 64 D100 with /6 doesn't have a fuse block. I'm in the process of swapping the engine , adding AC and modern stereo. The wiring is an accident waiting to happen, as one short and it could burn it to the ground. I'm wondering how to approach this and have some thoughts but, looking for suggestions. I have a experience and education in electronics. I've fixed and assisted several friends vehicle wiring issues. so I'm not afraid of rewiring this truck.
1) Buy a used wiring harness from another fused D100.
2) Buy a hotrod harness.
3) Modify the current harness.
4) Where is a good place to buy terminals, wire blocks etc.?
Thanks Craig
I'm going to attempt to fix this project and not make it any worse.
PostPosted: Mon Mar 27, 2017 12:37 pm
Take a look at Ron Francis Wiring you will find most of the bits & pieces needed to resurrect the harness.
