It is currently Tue Jun 02, 2026 8:02 pm
 Post subject: intake/exhaust torque
PostPosted: Fri Apr 14, 2017 8:42 am
Doc,
When using a Dutra exhaust manifold should I adhere to the 10Lb's/ft spec?? thank you
 Post subject: Yep... and...
PostPosted: Fri Apr 14, 2017 4:15 pm
Yes, it depends on the gasket, but I've done 5-7 lbs on a nicely mated set with Remflex(all flanges the same depth and true)... and have gone to 20 max on a remflex with a very horribly mated set (each manifold had a different flange depth)....25 is too much...
10 is a good number, especially with the composite gaskets that come in the rebuild kits...
 Post subject: thanks
PostPosted: Fri Apr 14, 2017 4:41 pm
Thank you! DI
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 8 guests
