It is currently Sun Jun 21, 2026 7:11 am
 Post subject: Where can I get this?
PostPosted: Sat Apr 15, 2017 11:30 am
I am missing a rocker spacer? I think it's called and I can't finish assembly and start it up without it. It goes under the bolt that holds the rocket shaft on.
PostPosted: Sat Apr 15, 2017 12:16 pm
We know what you mean, now where are you located? I can probably come up with one if someone close to you doesn't have one. Did you need just one?
Your picture didn't show up by the way.
Rick
PostPosted: Sat Apr 15, 2017 12:22 pm
Post an add in the parts wanted section, I'm sure someone has a spare. Specify which one you need, there's at least two different widths. I want to say the center one was the largest.
PostPosted: Sat Apr 15, 2017 2:38 pm
There are different sizes? Hmm I'm gonna have to find out which one I need.
PostPosted: Sat Apr 15, 2017 6:05 pm
Yep, I remember learning that lesson. I thought they were all the same too until after some head scratching and staring at rockers that didn't align with the valves very well lead to a different conclusion.
PostPosted: Sat Apr 22, 2017 7:54 pm
I have found the part I lost thankfully and ordered a physical copy of the manual. Hopefully this goes well!
