| Where can I get this? https://slantsix.org/forum/viewtopic.php?t=61013 |
| Author: | sagasky [ Sat Apr 15, 2017 11:30 am ] |
| Post subject: | Where can I get this? |
I am missing a rocker spacer? I think it's called and I can't finish assembly and start it up without it. It goes under the bolt that holds the rocket shaft on. |
| Author: | Rick Covalt [ Sat Apr 15, 2017 12:16 pm ] |
We know what you mean, now where are you located? I can probably come up with one if someone close to you doesn't have one. Did you need just one? Your picture didn't show up by the way. Rick |
| Author: | Pierre [ Sat Apr 15, 2017 12:22 pm ] |
Post an add in the parts wanted section, I'm sure someone has a spare. Specify which one you need, there's at least two different widths. I want to say the center one was the largest. |
| Author: | sagasky [ Sat Apr 15, 2017 2:38 pm ] |
There are different sizes? Hmm I'm gonna have to find out which one I need. |
| Author: | Pierre [ Sat Apr 15, 2017 6:05 pm ] |
Yep, I remember learning that lesson. I thought they were all the same too until after some head scratching and staring at rockers that didn't align with the valves very well lead to a different conclusion. |
| Author: | sagasky [ Sat Apr 22, 2017 7:54 pm ] |
I have found the part I lost thankfully and ordered a physical copy of the manual. Hopefully this goes well! |
