It is currently Wed Nov 18, 2026 1:04 am
PostPosted: Wed Apr 19, 2017 10:04 pm
After all the posts I have read one of the most recommended sparkplugs is the
NGK 3459 ZFR5N
Then all my research on boosted or nitrous says
mild boost 1 range cooler plug
Lot of boost 2 ranges cooler plug
I am not seeing a cooler plug listed for NGK ZFR5N so I contacted NGK Tech support and asked them what would be 1 cooler and 2 cooler plug starting at ZRF5N specs
1 cooler = NGK 4291 ZFR6F-11
2 cooler = NGK 5913 ZFR7F
And -11 is .043 gap and would need to be adjusted per ignition and boost
Any advise here as to ZFR5N with 7-8 lbs boost thanks
1963 Plymouth Valiant Wagon
PostPosted: Thu Apr 20, 2017 3:26 am
I believe that is the extended reach plug. I would recommend NOT using that type of plug for a boosted application. Based on some experience with turbo cars (increased detonation and at least one blown head gasket and melted piston), these are not good with boost. I cannot say for sure as these (2) were not my cars, but I trust the folks who made the observations (Drakes and Sam Powell) and so that is enough for me to avoid them.
I would get one of the following (or compatible equivalent):
NGK GR6, GR7, BPR6ES
Autolite 63
Champion RN9YC
NGKs might be hard to find, but maybe their tech support could recommend a crossover? I like NGK plugs, but am running Autolite 63s in my turbo Dart now and they have been fine. That is what I could buy at a local parts store last time I wanted to try new plugs and was on the road. I have been running a 0.038-0.040" gap, but as I go up in boost I plan to close this up to 0.030-0.032".
Hope this helps,
PostPosted: Thu Apr 20, 2017 6:24 pm
Thanks I had no luck looked all over
Not seeing gr6 or gr7 any chance you know the full ngk# ?
 Post subject: Yep...
PostPosted: Thu Apr 20, 2017 7:21 pm
Looks like NGK only has these in the platinum plugs now...
BPR6ES
I know that these are sometimes used by guys running NA High Compression...
PostPosted: Fri Apr 21, 2017 3:24 am
Thank you guys
BPR6ES are on the way 😎😎
PostPosted: Wed Jun 21, 2017 12:46 pm
Would these plug recommendations apply to a supercharged slant running low PSI ?
I am currently running the NGK ZFR5N plugs with a gap of 0.04" and HEI .
DRIVE IT,DON'T HIDE IT
PostPosted: Sat Aug 05, 2017 11:04 am
I have ran bpr7es lot # 5534 now I am using bpr9es lot #7788, I think they cross reference to champion rn63y and rn65y race plugs. with 10 to 14 psi I gap them at .025". seems too work.
PostPosted: Wed Nov 06, 2019 8:29 am
Car Model: 1966 Dodge Dart
Did a bit of poking around that I thought I'd add to this thread: NGK BR7ES is a non-projected tip plug with the correct sizing to fit a slant six and a cold heat range.
Matt Cramer
