It is currently Wed Apr 29, 2026 1:06 am
 Post subject: 904 kickdown adjustment
PostPosted: Tue May 09, 2017 5:46 am
trans has a shift kit and lokar hardware on a custom set up that has probably been done before, 4bbl and long tubes. it shifts but always shifts hard, so hard it busted the bell housing its getting welded no but don't want to repeat that again :cry:
PostPosted: Mon Jan 22, 2018 10:16 pm
Wow busted the bellhousing!! Thats a first. I think something else has happened to cause that.
PostPosted: Tue Jan 23, 2018 6:40 am
Did you have the long triangular reinforcing brace that bolts up to drivre's side of block and bell-housing in place when this happened? Or, has it been removed for header routing?
