It is currently Thu Nov 26, 2026 7:40 am
 Post subject: carb problems.....
PostPosted: Thu Jun 26, 2003 9:07 pm
i have a 1bbl on my 6......it is a holey card..... when i go to start the car the carb filled up wit gas then it leaked out down near the gasket on the manifold then the gas went all over the manifold......the carb has just been re-built....any ideas why it is doing that? if you have any ideas please e-mail me
grimsk8ter69@aol.com
dartman69
PostPosted: Thu Jun 26, 2003 10:53 pm
Sounds like a bad needle valve or a mis-adjusted or bad float.
Recheck those items to see if the fuel flow stops when the float bowl is 3/4 full.
PostPosted: Fri Jun 27, 2003 2:52 am
Can you tell where its leaking from? if it leaking out the bowl vent, you likly have a bad float adjustment. Basicly the float cant shut the gas flow off when the bowl get full. Also this could be caused by a bad float valve.
Other thing is improper or bad seal on fuel bowl.
GL
Mike C
http://cuda.iclownz.com
67 - Barracuda Coupe - 225 - Automatic
 Post subject: seen this before
PostPosted: Sat Jul 19, 2003 4:34 pm
When I rebuilt the 1920 Holley 1bbl in my '65 Dodge the rebuild kit came with this nice looking float valve with a viton o-ring in the tip. It might look like it would seal better, but in fact it was unable to stop fuel from pouring in. I took the carb back off and put the 30 year old all brass needle valve and seat back in and its been fine since.
Paul G.
