It is currently Sat Jun 13, 2026 11:53 am
PostPosted: Fri Jun 02, 2017 6:17 pm
What benefits, if any, does a true double roller timing set have over standard or matched?
If I was half as smart as I thought I was 30 years ago, I'd be twice as smart as I am now
PostPosted: Sat Jun 03, 2017 11:51 am
Car Model: 64 Valiant
A "true roller" has rollers that are made from solid round material, where as a non-"true roller" has the roller rolled into a circle and has a visible seam, and under extreme loading can fail easier because it isn't a solid piece.
PostPosted: Sat Jun 03, 2017 12:06 pm
So no benefit in lower rpm applications ?
PostPosted: Sat Jun 03, 2017 12:25 pm
Just about the hardest thing on timing gear is a rough idle .
PostPosted: Sat Jun 03, 2017 1:03 pm
My rule of thumb has always been get the best timing set you can afford and you'll likely never have to replace it. Best does not mean most expensive. Personally I don't care if the chain or valvetrain make a little noise if it means I'll never have it fail. I do not ever like using those nylon gears because they come apart and the pieces get sucked into places that cause further problems. I prefer the double roller type.
PostPosted: Sun Jun 04, 2017 4:55 pm
Thanks for the input
