It is currently Sun Nov 22, 2026 1:07 am
PostPosted: Tue Jul 18, 2017 12:36 am
My passenger side door hinge detent roller doesn't want to roll.
Awful noise (slightly less now, tried lubing).
Drivers door rolls like it should.
What the magic elixir that I can spray on it so it rolls?
Acts like it's rust welded to the shaft......
PostPosted: Tue Jul 18, 2017 4:36 am
Keep hitting it with PB Blaster let it soak for a day or two and exercise it, then repeat. Sooner or later it will free up enough to move at which time give it a good flushing of the rust & crud, and a white grease lube should fix it.
PostPosted: Wed Jul 19, 2017 10:32 am
Car Model: 75valiant custom
good advise. i had the same problem, and that's what it took!
PostPosted: Fri Jul 21, 2017 4:19 am
Here in the Northeast this is a common problem. Not so bad these days as the new cars have much better door sealing.
