It is currently Mon Nov 16, 2026 11:44 am
PostPosted: Sat Dec 09, 2017 2:47 pm
Car Model: 1962 Plymouth valiant v100 /6 3 speed column shift
Other than the FPC DOES ANYONE HAVE ANY INFO, PICS, DIAGRAMS OF THE INSTALLATION OF THE SHIFTER, BRACKETS AND HUMP?
THANKS,SLOMO
PostPosted: Sat Dec 09, 2017 4:08 pm
If you want to put a floor shift in a 62, I doubt the 61 pieces will work as the transmission in 60 and 61 was rolled over in relation to the floor where the shifter was mounted. Hurst used to make a shifter that could be mounted on a 62 after cutting an access hole in the floor. The 60-61 didn't require a hump, the Hurst could use the same type hump that you would use with a 64 up 4 speed installation.
