| 1961 valiant manual floorshift https://slantsix.org/forum/viewtopic.php?t=61698 |
| Author: | Slowmo [ Sat Dec 09, 2017 2:47 pm ] |
| Post subject: | 1961 valiant manual floorshift |
Other than the FPC DOES ANYONE HAVE ANY INFO, PICS, DIAGRAMS OF THE INSTALLATION OF THE SHIFTER, BRACKETS AND HUMP? THANKS,SLOMO |
| Author: | Exner Geek [ Sat Dec 09, 2017 4:08 pm ] |
| Post subject: | Re: 1961 valiant manual floorshift |
If you want to put a floor shift in a 62, I doubt the 61 pieces will work as the transmission in 60 and 61 was rolled over in relation to the floor where the shifter was mounted. Hurst used to make a shifter that could be mounted on a 62 after cutting an access hole in the floor. The 60-61 didn't require a hump, the Hurst could use the same type hump that you would use with a 64 up 4 speed installation. |
