It is currently Sat Jul 18, 2026 7:13 pm
PostPosted: Sun Dec 10, 2017 5:58 pm
Car Model: 1982 Dodge D150 Slant six 4 speed
I bought this Slant 6 from an older guy redoing an A100 yesterday and he said it was a 170 out of his van. Hell it was $100 for everything except the head which I will be searching for soon. Well I used the guide on how to identify a slant 6 motor on here and I’m having a little bit of trouble with the breakdown. From what I have figured out it’s a 225, here are the numbers off the deck.
AT225 2 02 2
Please help me figure it out
Thanks with any help in this. I can get pics of the numbers tomorrow after work too if needed
PostPosted: Sun Dec 10, 2017 7:13 pm
By chance does that engine have an adapter plate on the back of it?
PostPosted: Sun Dec 10, 2017 7:57 pm
Show us pictures, please -- especially show us the manifold side of the block. It's a 225 of one kind or another; the "AT22" part of the marking could mean either of two different things.
PostPosted: Mon Dec 11, 2017 12:46 am
I’m not sure I haven’t really looked it over but I never recall seening an adapter plate on it, but I will get pics today after work for you guys to look at
PostPosted: Mon Dec 11, 2017 4:26 pm
Ok after a long 12 hour shift here are some pics of the motor.
Last one
PostPosted: Mon Dec 11, 2017 4:29 pm
What my plan to do to this motor is make a peppier motor out of it and put it in my 82 D150. Now I know my starters will be in different locations, would that matter? and I also have an A833 4 speed, will that bolt up to this motor with my bellhousing that’s on my truck now?
PostPosted: Mon Dec 11, 2017 5:43 pm
I take it that the Van had the low mount starter manual transmission (hence no adapter?)? A-833 slant bell should have the high mount starter... Almost everything should bolt to this block, accessory-wise...
The biggest hurdle to overcome is year of the block and crank.. if the engine and crank is from a Pre-68, you're going to need to swap in a 1968-1976 forged crank, or get a custom bushing to mount the 1982 flywheel to the crank properly... or you could try to find a 1963-1967 small crank hub 122 tooth flywheel to use on it.... after that the build up should be easy... I hope you took measurements of how far the piston was in the hole at TDC so you can start estimating how much of a scrape you'll take off the block deck to get your target compression for more "umph"....
PostPosted: Mon Dec 11, 2017 6:15 pm
No the motor was already taken apart when I got it so I have no idea on that. I guess I may have to trade it for high mount motor then cuz I want a relatively easy swap when it comes time. It’s my daily driver and I can ride my Harley while I swap it out.
PostPosted: Mon Dec 11, 2017 6:38 pm
The trans/bellhousing determines the starter location, not the engine, itself. Did you get he crank? Measure the dia of the hole in the rear of the crank. That will tell you what you need as far as a flywheel.
PostPosted: Tue Dec 12, 2017 1:12 am
Yes I got the crank
PostPosted: Tue Dec 12, 2017 11:55 am
For what it's worth, that's a 1965 truck 225.
PostPosted: Tue Dec 12, 2017 4:37 pm
Thanks Dan?
PostPosted: Tue Dec 12, 2017 5:28 pm
Thanks Dan?
Yep. If the crank matches you have the following options to make this work:
1) swap in a 1968-1976 forged crank (You can swap the 1965 crank as a core after you order a 1974 Forged Crank kit for the rebuild...and will come with bearings too...)
2) custom bushing to mount the 1982 flywheel to the crank and center it properly
3) 1963-1967 small crank hub 122 tooth flywheel to use on it
PostPosted: Wed Dec 13, 2017 5:03 pm
Thanks Dan?
Ok Duster are the bushings common to find?
Can you buy the 122 tooth flywheel still
If you have info please let me know the places I can purchase
Users browsing this forum: Amazon [Bot], Google [Bot] and 8 guests
