It is currently Sat Jul 18, 2026 3:53 pm
 Post subject: slant belts
PostPosted: Mon Dec 11, 2017 5:23 pm
How do the belts run for alternator, air and power steering?
 Post subject: Re: slant belts
PostPosted: Mon Dec 11, 2017 6:28 pm
Clockwise from looking from the front. :P
Seriously, closest to the timing cover, is crank, A/C, and water pump
next out is crank, alternator, and water pump
front is crank, and power steering.
PostPosted: Mon Dec 11, 2017 7:03 pm
A guy gave me a motor with alternator air and power steering with no belts on it and only 2 pulleys on the crank How would that work?
PostPosted: Mon Dec 11, 2017 7:27 pm
Is the second pulley on the crank in front of or behind the harmonic balancer?
PostPosted: Mon Dec 11, 2017 7:42 pm
I think it is behind and their are 2 pulleys on the fan
PostPosted: Mon Dec 11, 2017 9:46 pm
Then it's missing the front pulley. The front and rear pulley bolt on to the crank vibration dampener with 3 bolts each. If you look closely at the crank pulley you should see 6 bolt holes - 3 of yours have bolts in, the other 3 don't
PostPosted: Tue Dec 12, 2017 4:54 am
That's correct. You got lucky that it's the front crank pulley you're missing. Easy to install, and fairly easy to find. Someone on here should be able to help you with one.
