| still tring to assemble needed parts for super six conversion https://slantsix.org/forum/viewtopic.php?t=61827 |
| Author: | alansDart75 [ Sat Jan 13, 2018 12:59 pm ] |
| Post subject: | still tring to assemble needed parts for super six conversion |
I'm still trying to figure out what to do about throttle and kickdown linkages. I'm also a little concerned with the studs and hardware attaching the manifold to the head. It looks a bit rusty, and I'd like replace it all if possible (I'm hoping everything comes off easily, I've been hitting it with PB Blaster daily. Also, where can I get studs for the exhaust flange from the manifold? Thanks all!! Alan |
| Author: | SlantSixDan [ Sat Jan 13, 2018 1:40 pm ] |
| Post subject: | Re: still tring to assemble needed parts for super six conversion |
Read through this thread for the sourcing info on manifold studs, nuts, and washers. It is very much worth your while to get the good gaskets for the manifolds-to-head and intake-to-exhaust junctions. See this thread for kickdown options. Studs for the exhaust manifold outlet flange…good question. I've never had to replace these; either I was using a manifold with holes on the flange (for bolt/nut fastening) or the stud-type manifold I was using was in fine condition. Manifold install: see here. How's your exhaust system, by the way? If it's getting time to replace the muffler, you might consider an exhaust upgrade while you're at it. 2-1/4" pipe off the manifold will give a big breathing improvement over the undersized 1-7/8" original (2-1/4" was standard with the factory 2bbl setup starting in '77). Muffler, tailpipe, and resonator info in this post. |
| Author: | alansDart75 [ Thu Jan 25, 2018 3:21 pm ] |
ok, I'm down to the wire....I believe I have all of the parts now, and even had the manifolds ground flat (which brings me to my questions) first off, the machine shop used grade 5 bolts to attach the intake to exhaust, do you think grade 5 is sufficient? Second, does anyone know that the torque should be between these two parts? Lastly, I am still trying to find a source for the special washers for mounting it all up to the heads. Thanks Alan |
| Author: | Panzerschreckleopard [ Thu Jan 25, 2018 3:50 pm ] |
Slant 6 manifolds have rather low torque values. i.e, the 1971 Plymouth Chassis Manual, page 9-9, lists 10ft-lb for the manifold-to-cylinder-head nuts (the super six manifold I have, in fact has said torque value cast into it), and 15ft-lb for the intake-manifold-to-exhaust-manifold bolts. Make sure you torque the former before the latter , for proper alignment. As for the grade 5, I'm sure it would work. I don't remember the exact bolt size, but you can just look up the size those new bolts are and compare to a table. |
