It is currently Fri May 08, 2026 5:03 am
 Post subject: Cam id ?
PostPosted: Tue Jan 09, 2018 2:07 pm
Car Model: 1970 Dart Swinger ( mod top clone ) Slanty w/auto
Hi All
I have picked up a motor and the bottom looks good
but i dont know if it has a cam ...it pulls to the 5k rpm range
Here is a pic of the cam it has a casted # ( EP 7 )
I think its stock ... we put a gauge on the EX spring and from open to close .375 or close to it ..
 Post subject: Re: Cam id ?
PostPosted: Tue Jan 09, 2018 5:42 pm
EP 7 only tell us that the "semi finished" camshaft "blank" was made by Engine Power Components Corp.
http://www.engpwr.com
Engine Power sells Slant Six cam blanks (p/n EP 7) to all the cam grinders. The cam grinders will then finish grind the cam blank to the needed spec.
You would have to pull the cam out of the engine and look at the rear journal face to see if the cam grinder stamped the grind or an ID number on it.
PostPosted: Tue Jan 09, 2018 6:22 pm
Couldn’t you figure out the profile using a micrometer and degree wheel? It would take some time, but it might be the only way to figure out the profile.
PostPosted: Tue Jan 09, 2018 6:56 pm
I have picked up a motor and the bottom looks good but i dont know if it has a cam
The photo you posted gives every appearance of showing a cam. If it's in the motor you're asking about, then yes, the motor has a cam.
PostPosted: Tue Jan 09, 2018 8:35 pm
Site Admin
Wise guy huh! :lol:
To the spirit of the question; you could use an indicator at the top of the valve to determine gross lift, and with careful setup determine events with a degree wheel. The indicator shaft would have to be set up very carefully to get accurate information. This, in effect, is how a cam can be checked for degreeing it in.
CJ
PostPosted: Wed Jan 10, 2018 11:54 am
Thanks Dan !!!! :lol:
Thank you Doug and the rest of you ... I knew it was a shot in the dark as to what it was
? for Dan and Doug
The head is stock on that motor ( head work to happen later ) is the
Oregon Cam Grind to much for a stock head with a 2bbl ?
Thanks
Me ..
PostPosted: Wed Jan 10, 2018 5:19 pm
Grind 818 at 108 LSA would be a good step up from stock along with a bit of port matching and clean up.
Grind 819 is the next step up after that, but would be nicer with a bump in compression.
PostPosted: Fri Jan 19, 2018 12:26 pm
Thanks
Duster ... i need to send the dizzy when i got things set up
Users browsing this forum: Bing [Bot], Google [Bot], Rick Covalt and 4 guests
