It is currently Sat Oct 10, 2026 7:04 pm
PostPosted: Mon Jan 29, 2018 5:43 pm
Car Model: 1966 Dodge D300 with 225 slant
https://www.glowshiftdirect.com/black-r ... ift-light/
I just ordered this digital tachometer to install on my 66' D300. I just want to make sure that I understand the installation properly. The gauge has a red (switched +), black (dedicated ground), and green (tachometer control wire).
I want to confirm that I should run the green wire to the negative side of the ignition coil.
Scott
1966 Dodge D300 with 225 3.7L
Scott C.
A family restoration and education project.
PostPosted: Mon Jan 29, 2018 7:54 pm
Yes, the green to the coil negative. The instructions do not appear to take into account points ignition until the end of section 2. and states:
"Tachometer Filter : It may be necessary to use a Tachometer Filter if you vehicle has an points style ignition system. You can purchase a Tachometer Filter from www.GlowShift.com or an Authorized Dealer."
Honestly, if it doesn't work properly with points they have gone really cheap with the tachometer circuitry. I would look elsewhere myself.
PostPosted: Mon Jan 29, 2018 8:38 pm
FYI- not to rain on your parade, but I tried a glow shift oi lpressure gauge once and was less than impressed wit htheir quality. I hope you have better luck, but you shouldn't be surprised if the tach has problems. Gloshift has some good gauge mouting products, though.
Users browsing this forum: Amazon [Bot] and 5 guests
