It is currently Wed Apr 22, 2026 1:06 am
PostPosted: Sun Feb 18, 2018 11:54 pm
3rd time I've had to replace this boot in 3-4 years over the original B&T joint on the driveshaft my 63 Dart. Something's not right...what would cause this boot to tear so prematurely?
Andy Bernbaum sold me one about 4~ish years ago, then did a make good on another a year+ later, now another year & 1/2 later, torn away again. :evil:
PostPosted: Mon Feb 19, 2018 3:34 am
How many miles on each one? I wonder if the old stock of them is just getting crusty? I doubt anyone is making them anymore. I wonder if some crossover from a newer CV joint application might be found? When I ran those, I just wrapped hefty trash bag around it and zip tied it on there and that lasted a few 1000 miles at least. You can convert the driveshaft to a truck slip-joint and standard U-joint type if you get the adapter flange.
I'm sure others will chime in here....
PostPosted: Mon Feb 19, 2018 5:30 am
What grease are you using? Certain kinds can attach particular rubbers. Try SuperLube.
PostPosted: Mon Feb 19, 2018 7:56 am
I took measurements and went to part store. Iirc, I took Opel Omega inner boot, but can't be sure anymore. It was years ago...
PostPosted: Mon Feb 19, 2018 9:13 am
It's a sign from Jesus Chrysler that good-quality parts for the ball & trunnion aren't available any more, so you should do this and be done with it once and frall.
PostPosted: Mon Feb 19, 2018 2:46 pm
The retrofit dan lists is a good alternative.. I brought a 64 dart with the flanged output 3 speed (oe) and it also has this style of driveshaft on it. No problems with it.
Btw, my car has a denny's driveshaft.
PostPosted: Wed Feb 21, 2018 11:24 am
Car Model: 1964 Dart 270
Yeah the drive shaft Denny's made for the 64 Dart I had works great. The flange and universal joint made it easy to mount did away with the old ball and trunion style driveshaft. No vibrations.
Steven
1964 Dodge Dart 270 four door. Three speed automatic 225 Slant with a Carter BBS carb.Image
PostPosted: Wed Feb 21, 2018 1:49 pm
I ran that setup in my Cuda for 10 years, no problems.It will be going into my 65 Valiant.
PostPosted: Fri Feb 23, 2018 7:23 am
Part number issue: Dana Spicer and several of the suppliers list a 2-3-8001KX slip yoke, but I can't find a 2-3-800KX.
Typo? Part number change? Or did my not-so-great eyes miss it?
Spicer Catalog Page 5, and Index pg 25.
Edit: Fixed the link.
PostPosted: Fri Feb 23, 2018 3:56 pm
Yup, it's a typo (missing that "1").
The 2-3-8001KX is specced out here. The 2-40-1711 spline is here, and as you can see it's a dimensional match (1.375" × 16 spline).
PostPosted: Sun Feb 25, 2018 11:31 am
http://www.dennysdriveshaft.com/c1035_flange_yokes.html
PostPosted: Sun Feb 25, 2018 1:45 pm
None of those is involved with the project at hand.
