It is currently Tue Jun 23, 2026 4:18 am
 Post subject: r
PostPosted: Thu Mar 22, 2018 1:34 pm
r
PostPosted: Thu Mar 22, 2018 1:36 pm
New cam showed up today!!!
225 ci 1968 block, 1977 peanut head no EGR
Dimensions:
Bore 3.430"
Stroke 4.125"
Rod length 6.698"
Head volume 39 to 40cc
Vel Pro Head gasket dia 3.525"
Head Gasket thickness .039"-0.041"
Piston down in hole .180"
New cam Oregon grind # 346
rocker ratio 1.5
Lobe separation 108*
Lobe center line Int= 1048 Exh=112*
Cam lobe lift I= .317" E=.319
Lash I=.012" E=.012"
Cam timing at .050" tappet rise:
Intake open=13 BTDC Close= 41 ABDC
Exhaust open=46 Close=2
15* overlap at 0.050"
Lift at valve intake= .476" Exhaust=.479"
Static compression ratio = 9.6
One calculator gave 8.7:1 dynamic ratio Elevation= 300'
Second calculator gave 8.2 Using 10:1 static dynamic =8.5
If my engine actually has static compression 9.6 and dynamic 8.16, from what I recall from other posts here, it should run on pump gas with no problem, is that right?
