It is currently Sat Nov 14, 2026 5:52 am
 Post subject: Pinion depth setup
PostPosted: Sun May 06, 2018 11:17 am
Hi guys, I am trying to set pinion depth on a 489 casting 8.75 chrysler rear.
I have some what seem to be oem used 3.91 gear set.
The depth tool i am using has instructions to follow to check depth of pinion etc. Problem is that there are no markings or stampings on the pinion gear head.. no checking distance or no +2 or anything.
The instructions reference those numbers.
Any help or alternatives appreciated.
I have loose set-up bearings and a micrometer for setting up and taking measurements. I have done this before using the tool and it worked fine. Those gearsets probably had checking distances stamped on the pinion.
Thanks,
 Post subject: Re: Pinion depth setup
PostPosted: Tue May 08, 2018 6:29 pm
You may have to start with about an .090" thick shim and check your pattern. PITA, but without a reference number you're flying blind anyway.
Did you get a solid spacer kit too? That makes life a ton easier setting it up.
