| Pinion depth setup https://slantsix.org/forum/viewtopic.php?t=62307 |
| Author: | Greg Ondayko [ Sun May 06, 2018 11:17 am ] |
| Post subject: | Pinion depth setup |
Hi guys, I am trying to set pinion depth on a 489 casting 8.75 chrysler rear. I have some what seem to be oem used 3.91 gear set. The depth tool i am using has instructions to follow to check depth of pinion etc. Problem is that there are no markings or stampings on the pinion gear head.. no checking distance or no +2 or anything. The instructions reference those numbers. Any help or alternatives appreciated. I have loose set-up bearings and a micrometer for setting up and taking measurements. I have done this before using the tool and it worked fine. Those gearsets probably had checking distances stamped on the pinion. Thanks, Greg |
| Author: | slantzilla [ Tue May 08, 2018 6:29 pm ] |
| Post subject: | Re: Pinion depth setup |
You may have to start with about an .090" thick shim and check your pattern. PITA, but without a reference number you're flying blind anyway. Did you get a solid spacer kit too? That makes life a ton easier setting it up. |
