It is currently Wed Nov 18, 2026 3:07 am
 Post subject: Fuel check valve
PostPosted: Sun May 06, 2018 9:04 pm
I drive my 61 Valiant about once every 2 weeks on a club run and it is hard to start as the fuel has drained back to the fuel tank (I think).
If I drive it daily, say on a 5 day tour, it starts easily each day.
I am thinking of installing a 5/16" fuel check valve in the flexible fuel line just before the fuel pump.
Any pros or cons on the installation?
 Post subject: Re: Fuel check valve
PostPosted: Sun May 06, 2018 9:07 pm
It's actually the fuel evaporating out of the carb.................
PostPosted: Mon May 07, 2018 3:03 am
Ok.
How can you stop the fuel evaporation?
PostPosted: Mon May 07, 2018 4:31 am
depending on the carb, it could be fuel draining into the manifold.
