It is currently Sat Nov 14, 2026 5:33 am
PostPosted: Sun Jun 10, 2018 7:19 pm
My reverse lights were working fine. I changed out my rear bumper to get it rechromed, ran an old bumper, lights were working. I just installed my newly rechromed bumper and my reverse lights don't work, or they come on sporadically. OK, so I'm thinking bad ground. I tested the lights with a battery, by touching positive to reverse light socket wire and touched negative to the outside of the the bezel - both work fine. I checked ground for each, there is good ground. I even hooked up separate ground wire from bezel screw to chassis, checked to make sure that ground is good, still when I put it in reverse sometimes one or the other comes on, but they flicker and don't stay on. So, I'm thinking this is something upfront, maybe the switch in the column is bad? What should I check? All other lights are working.
Brian
https://tinyurl.com/yynpj4v2
PostPosted: Sun Jun 10, 2018 7:22 pm
Extra Note: I had been working in the instrument cluster last week, had the steering column down, when I reinstalled it, the linkage was tight due to misalignment, but I got it back where it was supposed to be, linkage moves freely, car shifts fine. Could I have messed up the reverse switch in the column?
b
 Post subject: D
PostPosted: Sun Jun 10, 2018 8:03 pm
D
PostPosted: Sun Jun 10, 2018 10:56 pm
That was it. The switch was out of alignment. I removed it, cleaned it up, bench tested it, works fine. Reinstalled and adjusted, reverse lights are working perfectly, thanks so much. :D
Brian
